Any way to straighten bent guards on a sickle bar?
William Ransom
07-24-2004 12:18:25
The three guards at the left end of the sickle bar on the NI 251 mower are bent down. The second one from the left is bent so far that one of the blades can go over the part of the guard that's supposed to be over the blades. (They are all rock guards.) I tried to take the bent guards off, but I couldn't get the nuts to turn. I found a socket that fits the nuts on some of the guard bolts, but when I tried it on the ones for the bent guards, the socket slipped around the nuts. The nuts on the bolts that hold the bent guards on might be rusted fast (I really don't know if they are), but I know they are damaged so the socket doesn't fit them very well. I had thought I would take the bent guards off and replace them, but I now know I can't get them off by unscrewing the nuts with that socket. Can the guards be straightened? Since they are at the left end, do you think it would work to hit them with a sledgehammer with the sickle bar in the vertical position? Do you have any suggestions for how to remove them?
wolfy
07-26-2004 08:10:38
 Re: Any way to straighten bent guards on a sickle in reply to William Ransom, 07-24-2004 12:18:25
One good smack with a fairly heavy hammer - hit about half way back on the guard, farther back than you would think - on the wear, ground sliding side of the guard.
wolfy
07-26-2004 08:22:57
 Re: Re: Any way to straighten bent guards on a sic in reply to wolfy, 07-26-2004 08:10:38
Actually, not a very heavy hammer. I just use the flat end of the ball-pein that I use to replace rivets in sections.
Jim in michigan
07-26-2004 07:03:33
just like jms/mn said, use a 1 1/2 inch pipe and lean on it,. we use one all the time here, in the past 6 years I have yet to break a guard by straightening it this way,,,Jim
Kelly C
07-26-2004 06:02:38
3 years ago I picked up a $20 angle grinder. It is now my most usefull tool. Best $20 I ever spent.
I had to cut off 10 of the guards from my JD#5 when I 1st got it. Made short work of it.
JMS/MN
07-24-2004 17:37:50
Straightening? Inch and a half pipe, four feet long, and lean on it! Removal, 6 point socket, oxy torch, grinder. Sledgehammer is an option- what do you have to lose? Either they straighten, or they break. Either way, you can't cut the way it is now. When you get the entire bar lined up like new- check for an adjustment as to the bar angle, if you have rocks in the field. The guards should be at a slightly upward angle when cutting in a rocky field- they will ride over the rocks instead of digging into them. Most of the time- exceptions to every rule. Rocks come in all sizes and configurations.
Yo
07-24-2004 15:02:17
Guards can be straightened out if they are slightly bent. We built a guard straightener out of a 3/8 bolt and an old shear bar from the harvester. We took the bolt and bent it in a U shape then welded it to the ledger bare about three inches from the end. It worked quite well.
paul
07-24-2004 14:04:24
Guards can be adjusted a bit with a hammer to make them line up, but sounds like this is more than a small alignment.
You can heat with a torch & bend them back.
At any rate, get the nuts loose now & get things apart, someday you will break a guard when there is a short weather window & then you are sunk, trying to mess with old rusted stuff.
I'll assume you have a 12-point socket set. Get yourself a good 6 point wrench set, so that you can grip those nuts properly & get them off. Why any fool invented 12-sided socket set is beyond me. Worthless. Sockets like to pull at an angle & jump off, & these bolts are torqued down pretty tight. A good simple box end _6_ sided wrench would be best.
Don't bother going to the NH dealer for expensive replacement bolts - they just grab plow bolts out of the big bin & charge a lot. Go to the ag store & get the same sized plow bolts - that's the countersunk square headed bolt.
--->Paul
RickB
07-24-2004 14:26:09
 Re: Re: Any way to straighten bent guards on a sic in reply to paul, 07-24-2004 14:04:24
Those bolts are pretty spendy. The two sizes list for $.22 and $.44 each respectively. I semi-randomly picked NH46 mower for the price check.
Delbert
07-24-2004 14:18:24
Use cold chisel and hammer to cut the nuts off and as paul said go get new guards and bolts. You can get both at farm store for not to much money. As for the chisel hold it vertical to the nut and split the nut sometimes just a few hits will loosen the nut and will come right off. A little hint about the chisel clamp it in a pair of vise grips much easier on the hands if you should miss the chisel. Or angle grinder will do the job and you will be a happy mower again.
Dick Davis
07-24-2004 13:02:40
I would be amazed if you could straighten rock guards to where they are useful - probably break off. An angle grinder with a cut off wheel makes short work of rounded attachment bolts. I assume you aren't a welder with a torch? Maybe even a cut off wheel in an electric drill but that would be slower for sure. Just busting them off with a hammer still leaves you with the problem of replacing them - and you don't want to mow without the guards. My nickel Dick Davis
