Steve from New Holland or NHBalerman
Vern
07-23-2004 20:02:46
I have a NH 570 twine baler and sometime when it ties and the needles go back it shears a pin,I have adjusted the cable on the plunger latch and adjusted the timing and then retarded the timing and it works for a while and then it will go back to shearing pins. The baler is in good shape but it has had a lot of hay run through it. Has New Holland come up with some kind of service bullitin on this or something? I thank you for your help and all the help that both of you give to everyone on this board and hope that you can give me a good answer. Thank You
07-26-2004 14:04:57
 Re: Steve from New Holland or NHBalerman in reply to Vern, 07-23-2004 20:02:46
Vern, the baler is still slightly out of time. If you read this, email me at home and I will try to help you more. Steve
RickB
07-24-2004 17:05:35
Check the knotter home position and the knotter brake tension, and adjust if necessary. Did you pull the knotter back firmly into the home position before checking/altering the knotter timing?
