Knotter adjustment
DD
07-23-2004 10:40:25
So I have the operators manual for my NH271 that is having some knotter issues. It is occasionally having the twine hang up on the bill hook. One possible cause noted in the manual is that the knife arm may have insufficient lift (should be 3/8 to 1/2 inch clearance at it's furthest point). Only problem is the manual doesn't say how to fix this if it is a problem. Is there an adjusting screw or do you just bend it with pliers or pound it with a hammer? Options 2 or 3 seem rather dangerous in that something else could get out of whack. Help.
Joel Harman
07-24-2004 08:03:26
 Re: Knotter adjustment in reply to DD, 07-23-2004 10:40:25
Might look at your billhook tension too
massey ferguson
01-24-2005 21:43:47
 Re: Re: Knotter adjustment in reply to Joel Harman, 07-24-2004 08:03:26
dear sirs
please see if you can advise us .
we re looking for a knotter billhook for a masseu ferguson baler no 10 we would appreciate any help you can give us.
thank you ralph tenbrink
Roy in UK
07-24-2004 12:49:48
..... ..and twine tension, twine tension being too low can cause knots to hang on the billhook
Bob H.
07-23-2004 18:04:12
DD,The knife arm can be bent,I have used a pipe wrench,compare arm with the one that works,try to shape problem arm like the other,my knife arm was so misshaped I bought a new one,end of problem,HTH,Bob.
jd68
07-23-2004 17:02:17
DD, the lift on the sweep....knife arm is regulated by the brass cam bearing on the end of the knife arm. the only solution to your lift problem is to replace the brass bearing.
Are you sure that lift is the problem? My experience has been that the knife gets dull and dosn't cut the twine clean and then the knot dosn't sweep off the bill hook. Also be sure the sweep just lightly rubs the the bill hook.
Hope it helps..... ...
newground
07-23-2004 10:58:45
option 2 and 3 Be careful are the reccomended methods of adjusting this.
