Crop/Field Layout
Mark T.
07-21-2004 13:14:31
Just really curious about what I observed from a plane leaving Denver airport last week. Heading east, there are hundreds of fields planted in a circular fashion, most covering a quarter section. What is the purpose of the round pattern? What crops...hay?
paul
07-22-2004 07:37:33
 Re: Crop/Field Layout in reply to Mark T., 07-21-2004 13:14:31
Planting in a circle is really difficult. It puts undue stress on the planter, wearing the disks, closing wheels, & entire planter units out rapidly with the side-stress. Very, very rarely is that done.
The irrigation pipe travels in a circle, and will leave circular tracks in the field - even tho the crop itself is planted in normal straight rows.
--->Paul
Allan in NE
07-22-2004 07:50:38
 Re: Re: Crop/Field Layout in reply to paul, 07-22-2004 07:37:33
third party image
Thanks Paul,
You are right. Here is a bad picture of our system that I took last fall.
You can see the actual "farming" goes on normally underneath of the silly thing.
Allan
Allan in NE
07-22-2004 08:15:45
 Re: Re: Re: Crop/Field Layout in reply to Allan in NE, 07-22-2004 07:50:38
third party image
Found a little better picture of the goofy gizmo.
Rick in Michigan
07-22-2004 06:47:53
I saw 'em when I left Reno this spring and wondered the same thing. They are definately planted in circles, whatever crop they are.
It would make sense with the center pivot irrigation system. Seems like you'd get dizzy when harvesting the center of it 8~)
Allan in NE
07-22-2004 07:29:15
 Re: Re: Crop/Field Layout in reply to Rick in Michigan, 07-22-2004 06:47:53
third party image
Rick,
Is this what you are talking about?
They are center pivot irrigation systems and believe me, very few of them are "planted" in a circle.
They appear that way from the air because the machine provides water in a circular fashion. The most common size is 132 irrigated acres.
Allan
EZ
07-22-2004 06:09:32
My guess is that it is contour cropping. Around here (NE WI) farmers will plant around a hill to reduce soil erosion. They put alternating strips of crops all the way up the hill and that way water won't wash everything down.
Allan in NE
07-22-2004 05:16:07
Hi Mark,
I doubt if those fields were planted in a circular fashion; just looks that way from the air. We've gotta have water out here to make it, but most fields are planted in the usual manner.
There are so many holes poked in the ground here in western NE, that most NRD districts have placed a hold on any more new wells in fear of the water table dropping any more. :>(
I always thought that farming without irrigation would really be a tough go, but now I'm thinking of buying a half section of dryland just to scratch around on....go figure. Hmmmmm
Allan
JMS/MN
07-21-2004 18:03:01
Those are center pivot irrigators. Overhead pipe frame anchored in the center of the field delivers the water, and wheels pull it forward in a circular pattern. Some people do plant row crops like corn or soybeans in a circular pattern, but most align the rows n/s or e/w. Could be most any crop underneath the pivots.
