Gehl haybine crusher roll clearances
Ken Schmidt
07-19-2004 19:14:40
I recently purchased a Gehl 770 haybine. After fixing obvious broken parts, I used it to cut 1'st cr. hay. worked fine. I noticed that there is about a quarter inch clearance between crusher rolls. I suspect rolls should be atleast touching, but was hoping some mechanic out there would know for sure. Any advice would be appreciated. Second crop is coming on strong and the red clover is thick so I'll need all the drying advantage I can get. Thanks.
jp
07-19-2004 22:45:27
 Re: Gehl haybine crusher roll clearances in reply to Ken Schmidt, 07-19-2004 19:14:40
I have a GEHL 2160 and adjust the rollers for a 1/16" clearance. When I first tried it out, the rollers touched and would shred the drive chain when it ran empty.
