case 555/heston pt10 help needed
Jim in michigan
07-19-2004 18:00:05
My Case 555 haybine(heston pt10) is breaking the chain that runs the reel ,,everything spins free. but the reel chain snaps,,any ideas??? Thanks,,,Jim
JOE in MO
07-21-2004 13:41:21
 Re: case 555/heston pt10 help needed in reply to Jim in michigan, 07-19-2004 18:00:05
Mine did the same thing drove me crazy, till I bought a new chain and installed, it worked great last year after that...
Sid
07-20-2004 23:05:37
How worn out is the chain, and or sprocket? These will cause a chain to break.
Tim IN
07-20-2004 13:07:00
The most common reason I can think of is that the reel bearing behind the reel slip clutch is worn. If this were the case, then you could move that side of the reel all around when the chain was off. However, if the reel end is stable and turns freely, that wouldn't be it. I'm at a loss. Misaligned chain?
Jim in michigan
07-21-2004 20:05:17
 Re: Re: case 555/heston pt10 help needed in reply to Tim IN, 07-20-2004 13:07:00
It turned out to be the bearing,, we found out yesterday, drove 130 miles each way today to get the bearings,,bought all 3 for the reel and will fix it tomorrow,,Thanks,,,Jim
