Proper Method for Setting Bale Density?
marvin
07-19-2004 11:21:34
I have a Oliver 520 baler that I had loosen the the two springs that hold the compression arm down on the bale. I had done this to take a bale out of the shute on the back. I thought that I had reset them properly but the bales are too loose. So what is the proper method for setting these two adjustments to get a well packed bale? How do you know when the density is correct? Does the setting vary from crop to crop and field to field? I would assume that if you set it too tight that you could break bales and other things.
kyhayman
07-21-2004 10:57:42
 Re: Proper Method for Setting Bale Density? in reply to marvin, 07-19-2004 11:21:34
There are a variety of opinions on what proper bale denisty should be. Desired weight for length of bale ahs a lot to do with it. One thing that my JD manual says is that bale density may need to be adjusted as often as every windrow. No I certainly dont do that but I do check mine every hours. The rule of thumb I used when has stacking was tight to where I can just get a gloved hand under the string. With A NH automatic bale wagon (which required more density), I use "if I can force a gloved hand under the string they are too loose."
ET
07-20-2004 05:47:13
The rule of thumb I always heard was that when you pick up the bale the the string should 6" of lift off the bale. It needs to be ajusted every day and somtimes a few times a day.
bryan g in mo
07-19-2004 17:10:53
Your probably going to get alot of different answers on this one, I set mine by the weight of the bale, run a few bales through pick up one or two and check to see if they feel heavy or light. I have a good feel for how heavy I want my bales so it is easy for me, but this is going to vary per operator
paul
07-19-2004 11:47:11
You basically have to play with those 2 cranks all day long, to keep the proper tension. Different crop, different day, different humidity level, all makes a difference.
With blaer empty, you problably need to push a few bales out to form the chute full, then experement with more (or less) tension until the bales are coming out right.
Yes, they don't tie right if you have too much tension.
--->Paul
