Ferguson ABO 22 Help with R/R
ChrisinMa
07-18-2004 12:57:10
Recently purchased above mentioned disc and I need to replace the discs. I tried loosening the bolt at the end of the gang but everything on the gang seems to spin. I also need to find replacement parts for this piece if possible in the New England area. Any info is appreciated much thanks, Chris
Tim(nj)
07-18-2004 13:53:14
 Re: Ferguson ABO 22 Help with R/R in reply to ChrisinMa, 07-18-2004 12:57:10
My grandfather had an ABO22. When we needed to take that nut off, we put a big Stillson wrench over one of the spacer spools to hold it while we used another Stillson on the nut, AFTER heating it with the torch. What parts do you need? Bearings, if still available, aren't cheap. I got a new upper half casting maybe 8 years ago from an MF dealer and it was $99. Don't break or lose any spacer spools, they are hard to find. Blades are available from a variety of aftermarket sources.
