NH 617 Disc mower I give up
JC in ky
07-17-2004 12:18:05
Fellas Im puzzeled. I have a NH 617 Disc mower that we bought about 4 years ago. We started having trouble with the bearings going out of the gear box. When we take it apart there is no oil left and we can not figure out where it is going. We have replaces all the bearings and seals three times now. The third time was just last week. We got it togeather filled every thing up with oil, I mowed for about two days then the gear box locked up again. I took it apart this mornong to find another brand new bearing ruint and still no oil in the gear box. It dosn't show any signs that it is leaking any where. Im tires of rebuilding it only to last just a few days. Any help appreciated. Thanks in advance. JC
Steve from New Holland
07-19-2004 04:40:55
 Re: NH 617 Disc mower I give up in reply to JC in ky, 07-17-2004 12:18:05
Well JC, this can't be rocket science. The gearbox sits on the 1st module, so the only place for the oil to go would be that module it is sitting on. I don't know why your box doesn't hold the oil without looking at it, but that is the only place for the oil to go. Is that 1st module filling up? Steve
JC in ky
07-19-2004 20:50:58
 Re: Re: NH 617 Disc mower I give up in reply to Steve from New Holland, 07-19-2004 04:40:55
Ive checked the bottom pod and its not running into there . Ill just keep the oil checked every so often. If worse comes to worse Ill have the housing magnafluxed to see if there is any cracks that I cant see. Thanks for all your imput guys. JC
jd68
07-17-2004 17:50:47
jc have you tried to fill the bar and just let the mower site for a day to see if you can find a leak. A friend has a VICON disc mower that did
the same thing you are saying. The housing that all the gears and and drums fit into was weeping
the grease. It wasn't noticeable when the mower was cold the gear oil was too heavy but after it work for 1/2 hour and then let it sit the bottom of the bar would be coverd in gear grease.
When we really look at it close the bar had spider web cracks everwhere.
Maybe this helps.....good luck.
jls
07-18-2004 20:06:22
 Re: Re: NH 617 Disc mower I give up in reply to jd68, 07-17-2004 17:50:47
JD discbine of mine wipes off the oil on the stubble as I mow, never see any. Just buy 90 wt in 5 gal buckets and fill it JUST before I use it.
