gear box oil for JD403 brush hog
RustyHulk
07-16-2004 07:40:08
Can't find my manual and it's time to mow, but I need to add oil. Is 80-90w OK? Thanks in advance!
txblu
07-16-2004 09:25:04
 Re: gear box oil for JD403 brush hog in reply to RustyHulk, 07-16-2004 07:40:08
Most gearboxes require at least 90 and sometimes 140 for severe applications.
About grease, have used it for years on hogs with worn out seals. Never had a problem.
Full is not full. Should be a pipe plug on the side of the box about half way up from the bottom which is the full mark.
Mark
CJ
07-16-2004 08:45:53
Stick a finger,wire,something,in it to see whats there. If it smells/looks/feels/drips like 80-90,good to go.
Tim FL
07-16-2004 08:04:13
Most manufacturers recommend gear oil in the range of 90w. The most important thing though is just to have some oil in the box. I have even stuffed them with grease when the seal went bad and I didnt have time to fix, but I dont recommend that.
RustyHulk
07-16-2004 09:55:37
 Re: Re: gear box oil for JD403 brush hog in reply to Tim FL, 07-16-2004 08:04:13
OK, I'm ready to go. Found the pipe plug and used 80-90w to that level. Thanks for the info, maybe the manual will show up now that I don't need it.
Rusty
