MF 1560 baler
Tim
07-13-2004 18:29:42
I baled with my 1560 for the first time yesterday and it done ok exept for stoping up the first time i tryed to start a roll! It really didnt get the rolls very tight I had a 1000# of pressure on the hydraulic gage with pretty big windrows and about 5 or 6 miles per hour ground speed. I never run it at the full 540 rpm mark. Anybody know what i was doing wrong or do these old baler just not bale as tight as others?
joe e-tex
07-14-2004 19:47:44
 Re: MF 1560 baler in reply to Tim, 07-13-2004 18:29:42
i have two 1560s one will start a bale on fluff,other needs a nice size wind row,like my old 605c.both are in retirement or back up . belts make all the diffrenceand ground speed i move in 3 to 4 mph range,with large large wind rows.mades 1500--1800 pound bales nice and tight bales.SPEED BALING just wont work to fast no time to compress,no time to check bale squareness.good pick up teeth good belts make very good baler.im now working with 605 super j.and still drive same speed and have time to enjoy things,it might work at 5 mph but i will never know ,does 18 to 24 bales per hour.sorry for late post but ive been baling joe
Hay Dr
07-14-2004 05:27:16
If you do not run at 540 with a round baler the bale quality will suffer. The baler is designed to work best at 540. When starting the bale with this baler you need to start at low RPM's. If the windrow is not 5' wide start into the windrow at one side (30-45 degree) driving to distribute the hay from one corner all the way to the other corner. Once the hay has been distributed all the way across the baler quickly drive distributing the hay across the baler to the other corner. This is building your core. If you do not have a good uniform core it is hard to make a good bale. Now drive in such a manner to feed the corners and the middle will take care of it self.
James in NC
07-14-2004 05:20:07
When you start the bale make sure you get hay all the way across the chamber quickly. If you are willing to slow down some the bale will be tighter. More time to pack. As you stated it is an older baler and it won't bale as tight as the new ones though it should still but up a nice bale.
