Bush Hog Model 105 gearbox removal
JRF
07-12-2004 18:41:44
Need help removing gearbox in Bush Hog model 105.
I have the blades removed. Large nut on bottom of the shaft has been removed. How is the stump jumper attached underneath?
Thanks in advance,
JRF
Bill in TN
07-13-2004 05:50:36
 Re: Bush Hog Model 105 gearbox removal in reply to JRF, 07-12-2004 18:41:44
Your stump jumper is probably stuck. Soak it good with penetrating oil. There are a couple of ways I've removed it. I would put the blades back on, tie a chain around the blades close to the stump jumper. Put the nut back on the shaft and place a bottle jack on the shaft\nut, and put the chain over the jack, then jack and the stump jumper should come off. If you have a torch, a little heat should help free it up. Just an idea, hope it works for you.
