electric motor question on a grain auger
Charlie
07-11-2004 17:07:27
I just recently bought a 30ft grain auger with a 3 horse electric motor. The motor can run on 110 or 220V. My problem is on either voltage, the motor states it needs about a half amp more than the generator I will be using to run it has. Is it possible to run the motor with the stated amperage being that close to the amperage stated on the generator? I may need to find a bit smaller motor if I can't run it from my generator.
Russ Smart
07-11-2004 18:40:20
 Re: electric motor question on a grain auger in reply to Charlie, 07-11-2004 17:07:27
I doubt if your generator will start a motor that big, My 5 hp gen won't begin to start a 1 hp induction motor!
Bob
07-11-2004 17:55:16
The rating is FULL LOAD AMPERAGE. If the auger is fed fast enough to use the full output of the motor, that is the amperage it will draw.
Therefore, if you switch to a smaller motor, and continue to load the auger as heavily, the smaller motor will be underpowered.
Why don't you try what you have, start it empty, because the generator isn't gonna have enough reserve to start it loaded. Don't load it too heavily, and let it empty out when done, before shautting the motor off, so it can again start unloaded.
Wayne in PA
07-12-2004 17:29:46
 Re: Re: electric motor question on a grain auger in reply to Bob, 07-11-2004 17:55:16
I have a belt tightner on my auger, I loosen the belt start the motor and tighten the belt and away it gowes.
Wayne
