NH 276 baler suddenly shearing pins
Edd
07-10-2004 21:43:05
My NH 276 was baling great..grass hay for horse bedding but suddenly started shearing pins about every 10 bales.I sharpened the knives with an angle grinder..minor improvement. Next I really slowed down from 1800 RPM to 1500 Rrpm. It is better, but the problem is not fixed. Any ideas what to check. It usually shears when the knives try to make a heavy cut. Thanks for you ideas. Edd
Steve from New Holland
07-12-2004 04:47:00
 Re: NH 276 baler suddenly shearing pins in reply to Edd, 07-10-2004 21:43:05
Edd, the safety latch should be checked, but I bet you suddenly jumped time by one or two chain links. If you do not have a manual or do not know how to check timing, we can go thru that in a future post. However, my guess is that your baler is slightly out of time. New Holland balers have a small habit of jumping out of time for no reason and the 276 is as bad as any. Steve
Catskill Pete
07-11-2004 08:36:31
You might want to check to see if the safety stop is clearing the plunger arm completely. As the parts get worn, the safety stop won't completely clear the arm when it draws back. As the plunger passes it it "ticks" the stop. Very hard on shear bolts.
