J.D. 336 Baler w/ 30 thrower
Dave Sherburne,
07-09-2004 06:30:18
Thrower stopped kicking the bales to the back of the wagon . It will lob them just into the wagon. ANY IDEAS????? Its that hydraulic bale thrower
Bill B
07-09-2004 19:06:13
 Re: J.D. 336 Baler w/ 30 thrower in reply to Dave Sherburne, NY, 07-09-2004 06:30:18
Hi, I had the same problem a couple of years ago and I fixed it by replacing the 2 belts(which come as a match pair from JD). Some are adjustable and I think some have a spring loaded pulley. Pull the cover off and check the tension. Bill
Tim(nj)
07-09-2004 09:12:10
Check in this order. Low oil level? There's a filter in the tank, is that plugged up? Is the accumulator working correctly? Pump need rebuilding?
Tim(nj)
07-09-2004 18:01:11
 Re: Re: J.D. 336 Baler w/ 30 thrower in reply to Tim(nj), 07-09-2004 09:12:10
I forgot another simple little thing. Did the pin fall out of the joint between the rod and the indicator dial?
