NH 279 haybine
John K
07-08-2004 15:28:26
Well I went out to look at a haybine that supposidly hit a rock and had a bent sical bar table. He was asking 1700.00. The header bar if that is what you call it (the guards attach to it) was broken clean through about 18 inched to the right of the pitman arm. Hair line cracks around the sheet metal that hold the circular ring for the pickup reel, the pitman joint (not sure of the name) had about 1 inch of play in it, and the hitch was totally rebuilt. From the hair line cracks, the play in the pitman joint, and the wear on the sical knife, he must of continued to cut hay for a week or two. With all the replaced steel, hitch , and some other 3/4 X 2 flat iron on this unit, I turned tail and ran from there. Even the rollers had cracks in them. I can't believe that some one would have the gall to try to sell something so bad for so much. He even said that about 3 hours of welding would have it fixed up and the woble box is in great shape even though it was covered in oil and hammered out the pitman joint. I would turn it down for 500.00. He even called me back today to see if I had changed (lost my mind) mind.
