Spray Tank- aluminum or plastic?
Glenn
07-07-2004 06:56:04
I need to put together a broadcast sprayer primarily to spray for mosquitoes a few times a year over 20 acres. I've located a 200gl aluminum sprayer tank that appears to be in good condition w/rack that can be converted to 3ph. Price seems to be OK. Everything that I see is plastic now. Is aluminum OK or should I stay away from it? Pros and cons please.
paul
07-07-2004 21:22:54
 Re: Spray Tank- aluminum or plastic? in reply to Glenn, 07-07-2004 06:56:04
I would worry about any type of metal, probably works with most chemicals, but there are always a few that react badly. If you never use the reactive ones, it's up to you. RoundUp is really popular, & it reacts with iron, not sure on aluminumn....
--->Paul
Jhill
07-07-2004 16:11:18
You need to check compatibility of aluminum with your chemical. Aluminum can react with some and give off noxious gases. Plastic is pretty much neutral.
