Kuhn cutter
Tim
07-06-2004 14:40:18
I have an old kuhn hay cutter that i hooked up yesterday and ran it a little. one of the blade spools has a lot of play in it so much that the bottom of the blade bolts are striking the bar. does anyone know how to fix it. could it be a bad bearing?
James in NC
07-07-2004 05:11:06
 Re: Kuhn cutter in reply to Tim, 07-06-2004 14:40:18
It could be a bent disc or a bent shaft or more than likely a bad bearing. If this is one of the older ones you might have to spilt the cutter bar.
Andy from NZ
07-08-2004 18:03:45
 Re: Re: Kuhn cutter in reply to James in NC, 07-07-2004 05:11:06
No it wont be a bent shaft I work at a farm machinery workshop and fix lots of these mowers it is most probably the bottom bearing in which you will have to split the cutterbar if you do this it is worht replacing all the bearings on the drive gears 2 per shaft. These are great old mowers just keep an eye on the movement in disc bearings if you get them early enough the top bearing can be replaced without seperating the cutterbar
