Hi Mark, First of all I am really sorry that this happened, bad situation with not good solution. Also, take my thoughts for what they are, I havent seen the hay and havent done any tests. As a rule, cows will not eat hay that is so moldy it will make them sick if given a choice. By always letting them have access to some other hay they will pick and choose, either that or roll it and use it for mulch. Greatest hazards in 'regular hay' is botulism. IT takes moisture contents above 70% for this (not like to happen, but it only takes a tiny bit of botox). Other concerns on sudan are the micotoxins. Pink molds would be indicative of T2/vomitoxin (mainly a concern about repro problems in heifers), grey molds (penicillins), and faint black spec molds (aflatoxin, powerful carcinogin). There are some other potentially unidentified mictoxins but thos ewould be the big 3. By al means get it dry, this more than anything else will reduce spoilage problems. Good news, except for botulism it is unlikely to kill cows, and it is hard to kill a cow with botox (I lost 2 horses to it feeding out of the same rings as 100 cows and none of the cows ever even looked ill). Cows are much more tolerant than horses. I can pull out my old notes on micotoxins, see what else comes up and what labs test for what.
