New Holland 268 baler
Johnny
07-05-2004 11:14:30
I am new to hay and I have bought a new holland 268 now I can't seem to get more than 5 bales and the strings stop knotting and get all knotted up around the knifes, I was told I had to time it does anyone know how to time this, and adjust the knotters?
Thank you
George G
07-06-2004 16:38:01
 Re: New Holland 268 baler in reply to Johnny, 07-05-2004 11:14:30
I have a operators manual for the 268 Hayliner. email me [email protected]
SPEEDWAY SQUARE BALING
07-05-2004 20:45:11
i could be wrong but it looks like the twine discs are a little too tight if thats sisal your using(its a bigger diameter that bt170/7200 or what ever you want to call it) and that is a flat spot on that cam bearing/check it and also the look at the knife blade, by looking at the jagged sisal it could need sharpened. you might try palstic to see if it does any better, my old nh277 worked the best with 140/9000.
Kelly C
07-05-2004 19:10:59
third party image
Does not sound like a timing issue. You may have some other adjustments that are needed. Also some of the knotter parts may be worn.
Lift the knotter and look at the cam bearings. The one in the photo has flat spots. If yours are the same you may need to rebuild them.
Johnny
07-06-2004 19:50:42
 Re: Re: New Holland 268 baler in reply to Kelly C, 07-05-2004 19:10:59
the brass cams do have flat spots.but how do they come off?or do u have 2 replace the whole knotter? tnx john
Kelly C
07-06-2004 20:44:36
 Re: Re: Re: New Holland 268 baler in reply to Johnny, 07-06-2004 19:50:42
Go to my web site. Click on the New Holland 68 link on the left side. There is a link on that page that shows how to rebuild a Nh knotter. At least it shows how I rebuilt a NH knotter. The right way may be different but you get the idea.
Sid
07-05-2004 14:47:55
Based on what uou have said "can't seem to get more than five bales" I do not think it is a timing issue. If it were timing I think you would be shearing pins. On my New Holland 269(basicly the same baler) I have that problem when i set the tension too tight. It could be something else but as mentioned it is hard to tell you without you having a manual. The last manual I ordered from my New Holland dealer about six years ago cost me around twenty dollars. I have ordered some manual from other equipment manufacturers on line. You might try to find New Hollands webb site and see if it can be done there. I have gotten manuals from tractor supply, and other non branded dealers might be able to do it for you.
Tim(nj)
07-05-2004 14:47:00
A New Holland dealer. Find the serial number on the baler if possible, sometimes that determines which manual you need.
Tim(nj)-with more
07-05-2004 14:53:08
 Re: Re: New Holland 268 baler in reply to Tim(nj), 07-05-2004 14:47:00
800-635-4913 I have this number written down as New Holland Publications number. Not sure if it is still current (wrote it down 4+ years ago)
Johnny
07-05-2004 13:40:54
Do you know where I would be able to find a manual????
Tim(nj)
07-05-2004 12:23:08
Get an operator manual and a service manual. You will need them. Balers are too complex to fiddle around with.
