Case 2 bottom plow
Norman
07-05-2004 07:45:51
I have an old Case 2 bottom plow with iron wheels I am trying to restore as close to possible to original condition. What is the chance of finding some parts? I need a wheel and axle. Also, I need shares, moldboards, and landslides. I would love to find some literature on this plow like a parts list and schematic drawing to assist me in putting it back together. I know I need a lot but I think it is worth saving. It was a beautiful piece of engineering when it was working properly. Any help will be appreciated.
Jim
07-05-2004 20:51:06
 Re: Case 2 bottom plow in reply to Norman, 07-05-2004 07:45:51
I have some parts laying around. Parts by me, even though I live 30 min from Racine, are scarse as hen's teeth, so I bought up a bunch of junkers and cut them up. What size bottom do you have? If you have 16" you can still get the old shares from CASE, about $80.00 each. As far as an axle, what do you need? I have a 3-14/2-14 on steel with the open lift, a 2-16 on rubber with oil lift, and a 3-14 on rubber hydraulic lift I use and at least would have parts that I could give you pictures of. I also have a parts book that would tell which parts you need interchange with the rubber tired ones.Jim
Norman
07-06-2004 08:59:36
 Re: Re: Case 2 bottom plow in reply to Jim, 07-05-2004 20:51:06
Thanks for responding Jim. My plow is a 14" 2 bottom. Standing behind the plow, I need the right side axle. I have the wheel and axle for the trip mechanism. Also I need the piece that one moldboard bolts to, I have one.I guess this is called the frog or something like that. I have one rolling coulter,one very worn point and one landslide. Let me know by e-mail how much you want for what you have that I can use. Also I would love to have a copy of that parts book. I am in the Virginia Tobacco country. Norman Olgers,19310 Cox Road, Sutherland, VA. 23885
Jim
07-06-2004 17:01:27
 Re: Re: Re: Case 2 bottom plow in reply to Norman, 07-06-2004 08:59:36
Well, I have the moldboards and the axle, but I live in Wisconsin.
Don
07-05-2004 20:23:31
My father purchased a new "Centenial" Case plow in the winter of 1954. I still have that plow and I used it this spring. I also have the sales literature (brochure) of those plows. My father converted it to hydraulic lift before he used it, and I converted it to throw away lathes. Where are you located as I can send you a color copy of that brochure. Don
Norman
07-06-2004 09:05:59
 Re: Re: Case 2 bottom plow in reply to Don, 07-05-2004 20:23:31
Thanks Don: I am in Virginia, 19310 Cox Road, Sutherland VA. 23885 I would really appreciate a copy of that brochure. This was my Dad's plow and I would like to fix it and keep it for the family.
Jim
07-07-2004 19:46:59
 Re: Re: Re: Case 2 bottom plow in reply to Norman, 07-06-2004 09:05:59
Any interest in parts? I could maybe UPS them, have to check if your interested.
Norman
07-08-2004 05:25:58
 Re: Re: Re: Re: Case 2 bottom plow in reply to Jim, 07-07-2004 19:46:59
Jim, I am, let me know how much you want for the axle and moldboards.
Jim
07-08-2004 19:12:47
 Re: Re: Re: Re: Re: Case 2 bottom plow in reply to Norman, 07-08-2004 05:25:58
Well Norman, I have 1 moldboard that is a bit thin, I'd take $10.00 for it. I have 2 that are pretty good, one of them is almost new(very thick), and I'd plobably want $40.00 each for them. As far as the axle, make me an offer on it. It appears straight and not worn too badly, and came off a steel wheeled plow.
Norman
07-09-2004 17:54:49
 Re: Re: Re: Re: Re: Re: Case 2 bottom plow in reply to Jim, 07-08-2004 19:12:47
Jim, Thanks for staying in touch. How about $125 for the two good moldboards and the axle. I can send you a certified check for these items.
Jim
07-09-2004 17:58:43
 Re: Re: Re: Re: Re: Re: Re: Case 2 bottom plow in reply to Norman, 07-09-2004 17:54:49
Norman, could you send me your zip so I can figure shipping?
Norman
07-16-2004 05:03:54
 Re: Re: Re: Re: Re: Re: Re: Re: Case 2 bottom plow in reply to Jim, 07-09-2004 17:58:43
Jim, My phone has been out for several days and I could not connet to the net. My zip is 23885.
Norman
07-08-2004 04:56:34
Jim, I am interested. How much do you want for the axle and moldboards.
