International Grain Drill
Nick
07-03-2004 13:19:46
I was recently given an International grain drill model 10.It is in fair condition and I believe is serviceable with some work/ parts replacing. The mechanism on the front for lifting and disengaging the planting mechanism is somewhat apart. I would like to know if anyone has a picture of this thing or at the least can describe to me how this part is supposed to be set up and how it works. Was it rope trip or some other type? Also would like to know approx. how old it is. Doesn't really look too old. Thanks for the help. Nick
Hugh MacKay
07-03-2004 20:01:36
 Re: International Grain Drill in reply to Nick, 07-03-2004 13:19:46
Nick: Your drill is probably late 50's early 60's. I have forgotten the exact year of my number 10, I think 63 or 64 and it was hydraulic lift. I never saw a new clutch lift after I got mine. Clutch lifts were available after that, just not sure how long after. The number 10 became the 510 with some improvments, I'm thinking mid 70's.
Is your drill single or double disk openers? Most of the later models were double disk.
The clutch lift was a rope pull. It showed it in my manual, sorry I cant help you on just how it worked or even how it should look.
Nick
07-03-2004 20:29:06
 Re: Re: International Grain Drill in reply to Hugh MacKay, 07-03-2004 20:01:36
Mine is single disk. Is there supposed to be something that the tubes hook to on the bottom? These are just tied to the frames with wire just behind the disks. Doesnt really look original. I am not familiar with grain drills so I dont know. Also, do you have to pull something behind the drill to cover the seed? Thanks, Nick
Hugh MacKay
07-03-2004 21:17:11
 Re: Re: Re: International Grain Drill in reply to Nick, 07-03-2004 20:29:06
Nick: My No.10 was single disk and had accordian type rubber seed tubes. They used a wire clip to hold the end of tube in in the cast boot behind the disk. At the top end they clamped on with pipe or radiator type clamps. My drill was equiped with fertilizer hopper as well as seed and both went down that same tube. Covering of grain seed and fertilizer was done by the disks.
These drills could also be equiped with two grass seed boxes one for fine seed and one for coarse seed. The grass seeds from both boxes just fell behind the disks and were covered by 4" ring type chain pulled behind each disk boot. These had 3 to 4 rings and rings were joined by chain type links. My drill had both type grass seed boxes, and the only time I ever used the chains was if I were under seeding the grain with grass, just to cover the grass seed. I always rolled my land after seeding either way. If soil was real loose I have rolled land ahead of drill as well to give a firmer seed bed.
That clutch lift should work as follows; You must be moving for it to work. It has two positions at 180 degrees from each other that it will lock into. One is up and the other being down. Usually these are quite trouble free and last for years. They do need cleaning as the combination of grease and dust build up inside. This clutch lift principle was used for many years on a lot of different equipment. By the time it was perfected everyone went to hydraulics. Minkind's progress is a wonderful thing.
Tim(nj)
07-04-2004 10:43:02
 Re: Re: Re: Re: International Grain Drill in reply to Hugh MacKay, 07-03-2004 21:17:11
Hugh, on a dealer lot in Pennsylvania last year, saw a 13x7 5100 DD with what appeared to be factory clutch lift, and local made steel wheels and dolly-wheel hitch for a team. Still an option in the early eighties maybe, or someone figured out how to put a clutch off a 10 on there.
Hugh MacKay
07-04-2004 17:43:56
 Re: Re: Re: Re: Re: International Grain Drill in reply to Tim(nj), 07-04-2004 10:43:02
Tim: Wouldn't surprise me if that 5100 still had the hand cluch option. I couldn't find any info saying so, but did see a good photo of 5100 and not much changed in the actual working parts of that drill near as I can see. My drill was a 20 x 6, that was the largest available when new. Full of seed and fertilizer and the old 300 knew it was back there. I usually used 560 or 656. I think you could get 24 x 6 by the 5100 production. Wasen't enough to make me trade. Mine cost mere peanuts along side a new 5100.
