Vermeer R 23 A Rake Hay Doctor??
Mark
07-02-2004 16:04:26
Just bought a used R 23A double rake.I have a JD 4230 & a 605 H baler baling Medio & Gordo Bluestem in central Texas.? How wide do I set the width on the rear to make my first windrow & bale a good & tight Round bale hopefully!Lookes like I needed to replace a couple bearings.Thanks
James in NC
07-04-2004 06:25:46
 Re: Vermeer R 23 A Rake Hay Doctor?? in reply to Mark, 07-02-2004 16:04:26
The ideal setting for the windrow will 5ft. to match your baler. This will elimate the weaving, help to make level bales and put more hay in the bale since you are feeding it even. This also reduces wear on the belts. If the hay is to light for a 5' windrow then make a 2.5' windrow and go back to weaving. Also once you get to running the baler behind the rake you might want to look at putting haysaver wheels on the baler just like the new balers. About a $500 upgrade.
cannonball
07-03-2004 04:31:03
depends on how thick your hay is...i run mine most of the time closed up...have opened it a little in thick thick hay..run jd 566 and 4040 or 4230...have 2 twin v's....have nice day may god bless
