NH 68 Baler- Needles won't return to home position
Neil
07-02-2004 15:16:17
I have a NH S68 Baler. I timed the baler, the needles enter the chamber and when coming out they don't return completely to the home position allowing the safety latch to pull back. The plunger hits the safety latch causing the baler to shear bolts on the fly wheel. Does anyone know what is causing this? Thanks!
Ibby
07-04-2004 05:08:50
 Re: NH 68 Baler- Needles won't return to home posi in reply to Neil, 07-02-2004 15:16:17
I've had a NH 67, 68, and 69 baler, and everyone has needed the knotter chain advanced a link or three to avoid that problem. I don't know if the chains stretch, or what, but advance them a link at a time until the problem goes away. I also found it knots more consistanly.
JeffK-MN
07-02-2004 18:33:08
I have a NH S67 baler that I had the same problem last year. I timed it with the marks 4 times and broke the shear bolts each time then with the help of others here I had to advance the timing two links and that fixed the problem. I told the neighbor about how I fixed my baler and later he broke a chain and his was doing the same thing but this time we had to move the timing back three links. With the older balers the timing marks are just a place to start. Hope this helps Jeff
Kelly C
07-02-2004 21:12:14
 Re: Re: NH 68 Baler- Needles won't return to home in reply to JeffK-MN, 07-02-2004 18:33:08
My 68 was starting to do that again.
When you say advanced. Witch way is that. If you are looking at the 2 marks lined up from the rear.
Is advanced up or down from the other mark?
JeffK-MN
07-03-2004 03:33:40
 Re: Re: Re: NH 68 Baler- Needles won't return to h in reply to Kelly C, 07-02-2004 21:12:14
When I advanced it looking at the marks I moved it toward the front of the baler. Kelly C are you the one from Braham MN that was at the auction south of Ogilvie last year? We talked about this site. Hope it helps Jeff
Kelly C
07-03-2004 19:34:58
 Re: Re: Re: Re: NH 68 Baler- Needles won't return in reply to JeffK-MN, 07-03-2004 03:33:40
Yep thats me!!! You the guy with the Oliver and lives next to Pontos?
JeffK-MN
07-04-2004 16:59:15
 Re: Re: Re: Re: Re: NH 68 Baler- Needles won't ret in reply to Kelly C, 07-03-2004 19:34:58
Yes that is me with 2 Olivers I just got a new one for me it is a 1800 B stop by when you get this way Jeff
Neil
07-02-2004 19:39:53
Jeff, Are you referring to the main drive chain controlling the plunger and tines or the chain that controls the knotter and needles etc. When my baler broke down I broke the main drive chain and had to repair. Thanks!
JeffK-MN
07-03-2004 03:43:50
 Re: Re: Re: NH 68 Baler- Needles won't return to h in reply to Neil, 07-02-2004 19:39:53
When the neighbors chain broke it was the main one for the plunger but the whole baler was out of time. When my s67 was breaking shear bolts it was just the knotter chain I had to work on. Hope this helps Jeff
Neil
07-02-2004 19:36:12
Dick
07-02-2004 18:26:44
There is a threaded rod next to the knotter brake. You can adjust this to take the needles farther out. Also you may need to adjust the chain forward or back a half link on the sprocket to slightly adjust the timing. Take the hay out and get someone to turn the baler over by hand while you watch until you can get it right
