PTO QD Repair
ShepFL
07-02-2004 12:42:21
Last night my PTO QD pin on the bush hog broke. Been calling all day to find replacement. Everybody wants to sell me new yoke (unneeded). Don't they just sell spring loaded pin replacements?
Don't like the alternative of drilling thru the other side and using a Grade 2 bolt. That to me is not an alternative.
Thanks!!
Jerry/MT
07-04-2004 14:46:50
 Re: PTO QD Repair in reply to ShepFL, 07-02-2004 12:42:21
try www.valubuilt.com. I've seen them in their catalog.
paul
07-02-2004 21:47:21
There are slight differences, but you should find just the part you need. As the others say.
--->Paul
JMS/MN
07-02-2004 21:31:23
If you mean the spring-loaded pin inside the yoke that slips on the pto shaft...that part should be available at any good tractor or equipment dealer. It should certainly be available at the dealer who sells your brush hog. It is not a standard item- different yoke mfgrs use somewhat different pins, but I've run into only a few variances among mfgrs.
SPEEDWAY SQUARE BALING
07-02-2004 12:47:00
call your local newholland dealer, they normally carry them. ours here carry them for a large number of different mfg's.
