IH 37 Baler
Chris(Pa)
07-01-2004 18:31:27
There is a IH 37 baler with a #10 Kicker on it. The people say it is in good condition and ties good. i didn't call yet because I want to know what you think its worth, problems with it and how old it is. Thanks in advance.
Ray in Pa
07-01-2004 21:48:14
 Re: IH 37 Baler in reply to Chris(Pa), 07-01-2004 18:31:27
I use a IH model 37 baler with excellent results. They do a nice job of baling when adjusted to specification with a manual. I did discover that the baler over time can develope a tying problem due to slight wear in bill hook gear timing though. The bill hook timing has no adjustment to compensate for gear wear and will miss tying a complete knot when the bill hook timing becomes alittle late. On mine I did a simple modification that solves that problem, But it would take sometime to explain. I can explain this at some other time if anyone thinks they might be having this same problem with theirs. There are also some sealed for life bearings that should be water proof greased with injector needle and grease gun to prevent them from rusting solid and causing drag. Also it is a must to keep a slight drag on the brake and disc that holds things back for the tying needles. When it comes to the age of baler, I think they started building them in the late 1950's. Mine doesn't have a kicker, so I have no advice on how well those work. The price on a IH model 37 baler can vary wildly depending on condition and area of country. I have seen them sold from $200. to over $1,000. dollars.
Thanks, Ray in Pa.
Russ In Md
02-05-2005 14:53:21
 Re: Re: IH 37 Baler in reply to Ray in Pa, 07-01-2004 21:48:14
Does anyone know what a set of knotters should cost, are they still avaible ? I am thinking a new set of knotters will fix tying problem and be like a new baler.
Bob G
07-02-2004 13:27:25
Ray,
I have the #27 baler, which I believe has the same knotter assembly. Could you give the procedure of for them not tying a complete knot. The right side knotter(when looking from the back) pulls the string ends completely through the knot. I either have to stop and type it or if I miss it it usually comes apart. I have adjusted the bill hook tension, but that didn't seam to do it. I changed bale tension and that didn't change it. I happens occationally, but still makes you stop and look at it to see whats wrong.
bob
steve
07-02-2004 04:28:53
Ray, my 37 has that tying problem, it does miss one every now and then. If you could let me know what you did to fix it. Thanks
Ray in Pa.
07-02-2004 21:19:59
 Re: Re: Re: IH 37 Baler in reply to steve, 07-02-2004 04:28:53
Bob G. and Steve, The way the knots on my bales showed that the knots were tied incomplete was by that the front facing part of bale's twine would pull straight down out of knot when lifting the bale of the ground, OR more often than not, the bale would come apart even before exiting the baler. The twine running along top length of bale always had the single loop knot left when it pulled apart from front of bale twine. Tightening the knotter hook will not correct the problem due to the fact that it is not tying right due to being alittle late, or to be more precise, it does not complete its full rotation enough in time to grab the twine. I was amazed when I discovered that this is mainly due to the slightest bit of wear on the gear on end of knotter hook shaft, mine actually looks new, but yet it was enough to cause knotter hook to lag about 1/32" in rotation. What you should do first is to very, very slowly (and just alittle bit at a time) hand rotate your baler by its flywheel thru its tying phase to watch the tying action. You will notice the knotter hook will lag in closing (kind of hang open too long of time) and not grab the twine right before it is cut. The way I fixed mine was that I first loosen the knotter hook spring tension alittle and then remove the bolt that holds knotter frame assembly. Then I slow rotated by hand the whole knotter frame assembly up around onto top, and into area of no gear teeth section of the big gear. I carefully watched the knotter hook rotate itself thru the gear tooth section of the big gear and as I did this, I kept track of when the knotters hook cam rotates fully one revolution and stops in the low spot of the knotter frame. NOTE; If you carefully keep tension by hand on knotter hook to imitate tying pressure on knotter hook, as you do this, you should notice that the knotter hook cam will not drop in to position properly to allow the closing of knotter hook. What the problem is that needs corrected, is that the casting flat will need to be ground back by grinding tool to allow knotter hook cam to drop into the frame low spot sooner. To do this, you must remove the tension spring, cam tension plate and its bolt off knotter hooks frame. You will have to hold knotter hook frame in such away so as to be able to grind just enough metal to allow cam to clear and drop in properly. I used a dremel grinder with a long, skinny carbide rasp type of bit and ground back the casting flat around 1/32" for sooner knotter hook cam closing point. Fortunatly the knotter hooks starting postion will not be effected by this modification since it it controlled by the flat on the big gear. Basicly you want to grind just enough to allow the free closing of knotter hook when its under heavy tying pressure. When grinding, Just make sure to grind the flat as smooth as possible without hitting the knotter hook or its cam and to flush knotter hook assembly off with cleaner to remove abrassive grinding debris and relube.
Thanks, Ray in Pa.
ADDITIONAL INFO. Ray in
07-03-2004 09:34:44
 Re: Re: Re: Re: IH 37 Baler in reply to Ray in Pa., 07-02-2004 21:19:59
Note that the impotant part of the knotter hook to watch when hand rotating the knotter hook frame up to top of the big gear is called knotter hook roller. Once you have hand rotated the knotter hook frame assembly to top of big gear, begin to rotate the the knotter hook frame back down and that is when you will see how the knotter hook roller follows over the frames cam and will fall into the deep low spot so as to close the knotters hook. Grinding this side flat of the deep low spot of the frames cam allows knotter hook roller to drop in sooner and will fix the problem of knotter hook hanging open too long when under tying pressure. Also be carefull not to touch knotter hook roller when grinding. I also wanted to mention that the IH model 27 baler has the same knotter hook assembly from what I can see in the manual.
Thanks, Ray in Pa.
Bob in Indiana
08-01-2005 09:29:10
 Re: Re: Re: Re: Re: IH 37 Baler in reply to ADDITIONAL INFO. Ray in , 07-03-2004 09:34:44
i have that same issue, miss's one bale in ten or fifteen. also have a problem of a 6' bale kicking out when you slow down on the the feed. or stop. i think that the gear is worn that rachet's the lever to tie the bale.
am i thinking right?
thanks, Bob
