Question for Steve from New Holland
Tim
06-30-2004 06:56:41
I have a New Holland 488. My question is this, when I am in very heavy hay and a lot of times when I am making a sharp RH turn I can here a (single) loud pop. I do not think that it is coming from the drive line assembly but rather from inside the swather itself. I sounds like a chain jumping one tooth on a sprocket. I have checked the tension on the chains and all seems to be correct except the chain that drives the top conditioner roll. It has just a slight amount of slack in it but not enough to take out a link. If I am in lighter hay I hardly ever hear this pop noise. Also I backed the roll tension off to about 3-4 turns and that seemed to help a little but did not eliminate the problem. Any Ideas?? Thanks
07-01-2004 04:38:20
 Re: Question for Steve from New Holland in reply to Tim, 06-30-2004 06:56:41
Tim, I must admit, I don't know. Rick's idea is a good one, but I wonder if this would happen each and every turn. I'll think about it. Steve
RickB
06-30-2004 15:05:04
If you're turning REAL sharp making square corners, the right end of the bar is backing up over the cut swath. The reel sucks a clump of already cut hay through. The pop is the top roll slamming down on its stop pad.
