turning hay
Frank
06-29-2004 14:28:57
When turning hay to help it dry do you turn it to the outside of the field (the opposite way you swath it) or do you turn it to the inside (the same direction that you swathed it)?
Bob H nw Oh
06-29-2004 15:27:37
 Re: turning hay in reply to Frank, 06-29-2004 14:28:57
Frank,I just turned hay with my 70 year old NI rake,ran it in reverse like a tedder.Picked the hay up and dropped it without moving it sideways,went CW same as I mowed it,HTH,Bob.
Rick
06-30-2004 09:15:38
 Re: Re: turning hay in reply to Bob H nw Oh, 06-29-2004 15:27:37
I was just wondering how you can run a hay rake in reverse? It sounds like a good idea.
Mike (WA)
06-30-2004 12:38:31
 Re: Re: Re: turning hay in reply to Rick, 06-30-2004 09:15:38
Some of the old ones are set up to do that- New Idea and AC come to mind, maybe the old David Bradleys, too. The AC was PTO driven, and worked better than the others, I think. They have a lever that reverses the gears in the gearbox. It helps fluff up the hay after getting rained on, etc, but is kind of hard on rake teeth. Have a lot of spares on hand!
SPEEDWAY SQUARE BALING
06-29-2004 14:51:18
i always move mine to the outside, it helps keeping the center row from being 4' tall.
