Atrazine Residual??
Joe
06-29-2004 07:47:01
I bought some land last fall, and without checking planted some alfalfa/timothy on it this spring. Some of my alfalfa is turning yellow and or turning purple/maroon on the leaves. Obviously this isn't good. Later I found out that atrazine was used on the land last year. Could this be some residual? Or do I have another problem?
bstrucker
07-01-2004 08:49:02
 Re: Atrazine Residual?? in reply to Joe, 06-29-2004 07:47:01
Leafhoppers turn alfalfa brown.It looks like it is dying.Risidual atrazine will kill it.Yours is a nourishment problem.Get the tissue test done to find out what you need.
Iowa Jim
06-30-2004 07:55:12
Sounds like Leaf Hoppers to me.
Farmer Gene (NW WI)
06-30-2004 05:44:46
not enough boron will cause leaves to be yellow
not enough sulpher will cause leaves to be blue or purple. You can take a plant to your ag office and have a tissue test done to tell you what nutrients are lacking. Did you do a soil test before you planted?
jdp
06-30-2004 04:37:26
yes this spray can have carry over, especailly if more then 1 lb per acre was used.
Hal
06-30-2004 15:18:25
 Re: Re: Atrazine Residual?? in reply to jdp, 06-30-2004 04:37:26
Also, did you apply any lime? If so, raising the pH can cause the atrazine to become "unbound" where it can become more active and cause problems. If you can, find out what rate of Atrazine was applied. I think atrazine tends to linger longer in heavier soils that get little rain/snowfall.
Tim(nj)
06-29-2004 15:16:59
Do you see any of those derned little leafhoppers in there? Their feeding habits can change the alfalfa plant color.
