JD 37 Sickle Mower Question
Bill
06-28-2004 16:38:31
I just got a JD 37 sickle mower. The frame/etc is in good condition, but the pitman drive sheave/flywheel has a broken portion about 2" long around the edge, and the crank pin was welded back on. Is this a typical failure with these mowers? Since the mower has no slip-clutch on the upper drive sheave (from PTO) like some IH mowers I've seen, or any kind of shear pin, how do you keep from damaging the sickle or the pitman or the crank pin if a solid object gets in the sickle? Does the belt slipping usually prevent damage?
Does the JD 450 mower have a slip clutch or shear pin?
Thanks.
jeff
06-29-2004 15:39:00
 Re: JD 37 Sickle Mower Question in reply to Bill, 06-28-2004 16:38:31
bill i bought a 37 at a farm auction with intentions of repairing it .well there were more parts missing than i realized.the upper pully ,hyd cylinder.the cutter bar assy appears to be in real good condition if you are interested in it for parts give me a shout.thanks jeff
Bill
06-29-2004 17:53:40
 Re: Re: JD 37 Sickle Mower Question in reply to jeff, 06-29-2004 15:39:00
Jeff:
I would like to discuss this in detail with you. Please email me off list. Thanks.
JeffK-MN
06-29-2004 05:40:17
I have a JD 38 sickle mower with the same flywheel and belt. The belt slips when the sickle becomes stuck. I have had rocks stuck in the sickle with no damage. The best thing I did was to get a manual from e-bay for $5.00 and that showed me a lot of tricks. Good luck and if you have trouble I try and help with the manual Jeff
