removing a twisted PTO shaft
William Ransom
06-28-2004 14:59:04
Has anyone ever replaced a New Idea 251 sickle-bar mower's 3/4 inch square shaft (the rear-most part of the PTO shaft)? The rest of the PTO shaft (including the rear universal joint) is all right, but the 3/4" square solid shaft is twisted. The shaft was both riveted and welded to the universal joint. I tried to cut the weld with a hacksaw, and I cut one end off the rivet. I tried to drive the rivet out with a hammer and punch, but I couldn't get it to move. Do you have any suggestions for how to get the twisted shaft out so I can put a new shaft on the universal joint? Or do you think I could get a replacement universal joint easily enough?
Michael Soldan
06-29-2004 04:56:55
 Re: removing a twisted PTO shaft in reply to William Ransom, 06-28-2004 14:59:04
JMS has the right idea here, most farm machinery dealers carry all components for drive lines and you may be able to buy the end and shaft stock fairly reasonable. failing this I would get a metal cut off saw or put a cutting wheel on my grinder and cut the end off and clean it up with the grinder so it can be welded onto the new shaft. Good luck from Mike in Exeter Ontario
JMS/MN
06-28-2004 16:17:50
You could drill out the rivet and grind off the weld. The shaft is twisted, so you need a new shaft anyway, and a u-joint is maybe 15-20 dollars. Check with a welding shop or dealer with the Welda-sprocket/pulley/joint displays.
William Ransom
06-29-2004 10:44:15
 Re: Re: removing a twisted PTO shaft in reply to JMS/MN, 06-28-2004 16:17:50
I have cut the weld well enough -- the shaft is now a little bit loose in the u-joint, but the rivet still holds it in, and I still can't get the rivet to move at all. I tried to drill it out, but the drill bit broke, and I really don't think I did anything with it wrong.
