Hesston 5530 Baler Problem
Larry
06-27-2004 06:20:29
The pick up rake keeps throwing the drive chain. Does anyone know what the problem might be?
rob
06-27-2004 07:16:50
 Re: Hesston 5530 Baler Problem in reply to Larry, 06-27-2004 06:20:29
My square baler was doing the same thing earlier in the season, I just kept putting it back on, sometimes 5 or 6 times a day, and finally it stayed and havn't had anymore trouble with it. I don't know what caused it.
Sid
06-27-2004 06:50:21
It has been my experience that when ever I have a problem withloosing chains that the chain and sometimes the sprocket are worn out. The other problem that I have run acroos is that maybe one of the sprockets had worked loose and is out of line.
jamie
08-06-2004 09:56:36
 Re: Re: Hesston 5530 Baler Problem in reply to Sid, 06-27-2004 06:50:21
the baler you are talking is a roll baler you need to check to see with the wooden tenison blocks are worn out for the drive chains i believe there are two are or three on this model
