rotary cutter to finish mower conversion?
Shannon 135
06-26-2004 09:30:09
I have been using my 5'rotary cutter behind my MF135 to mow grass on 10 acres. I can't afford a finish mower right now and had an idea. Has anyone tried adding casters to the front corners of a bushhog so you can set it down on the ground while mowing and keep the skids from tearing up the ground while going over humps and turning? My blades are sharp and it cuts great but marks up the ground if I don't keep an eye on it and consantly raise and lower it while mowing.
