Finally got all my hay put up.
BobG
06-25-2004 21:36:14
I finally finished putting the last of 12 ton in my pole barn tonight. I cut the last 7 acres last Sunday, raked on Monday and bales on Tuesday. Tuesday I worked outside in the 105 degree heat, started baling at 3:00. My old M just has the wide open air for air conditioning. Loaded a ton and half on my old Ford one ton and took it home unloaded it that night. Worked the rest of the week in the same heat was too worn out to haul hay. Finally gave up and hauled the rest tonight. Next week the forecast calls for mid 70's, just can win.
BobG
Eric Rylander
06-26-2004 15:47:51
 Re: Finally got all my hay put up. in reply to BobG, 06-25-2004 21:36:14
Square bales I assume, dropped behind the baler?
Loading them up on the flatbed of a Ford 1 ton that's about three feet off the ground all by yourself in that heat? Man, you are tough!
When I was a teen ager, I worked for a guy who had made low, single axle 8' bed (between the axles) 16' long trailers about 10" off the ground using a moblie home axle welded directly to the frame for hauling the bales. What a difference! He never pulled a wagon behind the baler, so having conventional hay racks was't important to him. Much easier to toss bales on a wagon less than a foot off the ground than one at 30" +
Eric
