Haybine help needed
Tom in Michigan
06-25-2004 07:21:05
I recently bought a 9" New Holland haybine. I never used one before since I cut with a sickle mower and use a conditioner behind my IH H. I start cutting a feild by going counter-clockwise around to get the edges and then reverse and finish the feild in the correct direction. The question is can I also do this with the haybine or is there a better way? Thanks for any help or pointers you can give me.
Tom
Tom in Michigan
06-28-2004 06:57:02
 Re: Haybine help needed in reply to Tom in Michigan, 06-25-2004 07:21:05
Thanks alot guys for the help. I cut some hay yesterday. Haybine worked good.
Tom
Don-Wi
06-25-2004 23:09:11
I always do the clock-wise rounds 1st, then do the cc, it's easier to judge where the machine can/can't go, atleast for us. Where the outside tire ran down on the 1st pass, is where the outside edge of the haybine will be (give or take a few inches). It's what I was taught and what I practice, and it's always worked. Best to try and see what you like.
Donovan from Wisconsin
dan
06-25-2004 15:50:03
i always mow the meadow befor i do the back swath it always seems if your gonna break something its on the back swath
JohnE
06-25-2004 13:49:56
Tom, That is the way I do it too. If there is a better way, no one has told me about it. I suppose you could cut a field in many different ways. This way just seems the best to me.
JohnE
