Just traded for finish mower
Kent
06-22-2004 12:40:31
I just traded for a Woods RM-990 7 1/2' finish mower. It is a '99 model and has the earlier style gear box. It has sat at the dealer since last year due to the gear box lower seals leaking. I talked with Woods Tech Dept and they say it probablly blew them out due to the dip stick breather being plugged. The dealer is fixing it all up and adding a front roller and it already has some chains. Does anyone have one of these?? All I have heard is good things so far! Do you think it would build up enough pressure to blow out the seal?? Thanks, Kent
Kent
06-23-2004 06:22:26
 Re: Just traded for finish mower in reply to Kent, 06-22-2004 12:40:31
I contacted the dealer and asked what tractor he had the mower on. I guess my facial expression must have been pretty bad as he kinda looked at me funny when he said a 4020 I thought he was joking but he was serious. I now am wondering if he abused it some how with too big a mule?? I guess either way they are making the gear box right and will stand behind it. When I talked with Woods they said I could rebuild my box for @$325 and I could put on the new style box with a upgrade kit for under $300, that seems a no brainer which to buy if the box is trashed. Thanks for the ideas and help. Kent
Rick K.
06-23-2004 06:07:17
Kent,
A lot of people will say a blown seal is because the gear box is not vented. I have plenty of older equipment without vents and the only seals I have blown are due to a worn gear box with way too much runout on the shaft (bad bearings). But, as the gear box gets hot the oil wants to expand, so a vented plug is definitely a good idea. Even King Kutter puts them on their equipment. When I change the oil or check it, I add a vented cap. But I am not tearing out all my plugs to replace them with vented ones. I would wonder why your mower leaked, bad seal, runout? 1999 is pretty new and finish mowers don't take a beating like brush hogs and such. I have seen more than one occasion of seals getting blown because someone fills the gearbox to the top, not to the site plug. Even a tiny burr on the shaft can wreck havoc on a seal.
Just my two cents. Rick
RickB
06-22-2004 17:40:04
I brought one home from work that had been abandoned as dead. New blades, a belt, ran it for a year. I then fabricated front gauge wheels (originals MIA) and am now on my 3rd season. I love it. Absolutely the only Woods equipment I would consider owning.
Robert in W. Mi
06-22-2004 17:07:11
Just make sure the breather doesn't get plugged and you won't have pressure build up. Ask your dealer how to check it, and you should be fine.
Robert
