IH Little Clutch
Wayne M Kittler
06-20-2004 15:29:08
Does anyone know how the pick-up clutch works on the Little Genius plow. I can move the plow okay, but when I pull the string to raise the plow, the dog assembly seizes the out of furrow whell and it will not raise the plow or rotate.
rustyfarmall
06-21-2004 04:31:22
 Re: IH Little Clutch in reply to Wayne M Kittler, 06-20-2004 15:29:08
Take that assembly apart and give it a good cleaning. It is probably full of old hard grease and dirt.
john *.?-!.* cub owner
06-20-2004 20:38:57
It's been so many years since I saw one apart that I don't remeber much about the construction, but the way it works is to lock the wheel to the cam arm that raises the plow. Make sure all the pivots are greased and free. Also if on wet grass they are bad to slide instead of roll and lift.
