Twine cutter on Deere 510 baler
Hilltopper
06-20-2004 13:46:26
I use my brothers 510 roll baler. I pull it with my 720D Deere. I have sharpened the knife and adjusted the arm to put more tension on the cutter, but it seldom cuts through the twine. The cylinder that operates the cutter is very small and with a low pressure system it must not be strong enough to cut the string. It doesn't give any problems with his later model tractors. Any one had this problem?
txblu
06-21-2004 05:58:17
 Re: Twine cutter on Deere 510 baler in reply to Hilltopper, 06-20-2004 13:46:26
Maybe you could use roll twine vs the larger dia square twine. Don't know if your knotter will tie it but it feels about the same and both are made of poly. Seems tough enough to hold a square bale.
Mark
