New Holland spreader
Jim A.
06-17-2004 17:50:34
Does anyone know how big of a job it is to remove the apron chain driveshaft at the rear of a New Holland 680 box spreader? I've got a broken apron chain drive sprocket. Spreader is empty, thank God.
Steve from New Holland
06-19-2004 04:28:28
 Re: New Holland spreader in reply to Jim A., 06-17-2004 17:50:34
Jim, if you remove the shaft and gearbox as an assembly, it is not too bad. Which sprocket is it? If it is the left one, have a barrel of fun. If it is the right one, it may not be too bad. If you look, the shaft and gearbox and right hand bearing are setting in removable mounting plates. Steve
Jim A.
06-19-2004 20:07:25
 Re: Re: New Holland spreader in reply to Steve from New Holland, 06-19-2004 04:28:28
Steve, it's the left one. After I remove the gearbox and shaft, can the shaft be pressed right out of the gearbox, or is there more to it than that? Thank you very much for your help!!!
