John Deere #9 sickle mower
Jim.UT
06-17-2004 09:49:00
I ran the end of my mower into a fence post and broke off the last couple of inches off the knife bar. I have everything I need to repair it (sections, rivets, even a new knife head) but I need the bar itself. JD dealer says "obsolete". They show a dealer in Colorado that has one in stock but we're waiting to confirm that. CAL Ranch only sells complete knife assemblies. Anyone have any bright ideas or other sources for parts like this? It's a 7' blade. JD part number is H24592 but it's obsolete. Thanks.
JC
06-17-2004 23:47:02
 Re: John Deere #9 sickle mower in reply to Jim.UT, 06-17-2004 09:49:00
I good welder should be able to repair the sickle, or if you are a welder, you can do it yourself.
You have to use medium setting on your arc welder, hot enough to penatrate without excessive heat. Use a good filling rod.
Use your grinder and grind both pieces of broken metal so the end comes to a blunt point.
So the pieces look like two chisals placed blade to blade. Do not take too much metal off, or you will burn through.
Weld and knock off your slag several times to fill in where you ground the ends.
After it is filled, grind smooth and then drill any hole you might have had to fill.
You should have a real good spare that you could use in a pinch. If all is done right, you should be happy with your repair.
Jerry D in NC
06-17-2004 10:32:54
Jim,
Before you spend anything on patching and repairing, check sickleservice.com and see what a complete new bolt on sickle would cost and weigh that against the repair. Bolt ons are so much better when you are in the field and need to make a repair. You might need to change the hold downs but now is a good time to make the investment.... Call the man and see what he would be ableto do for you.
Jim.UT
06-17-2004 11:24:50
 Re: Re: John Deere #9 sickle mower in reply to Jerry D in NC, 06-17-2004 10:32:54
Thanks Jerry! I followed your advice, but only partially. I called and talked to John Webb (my name is Jim Webb so we might be distant cousins). A complete riveted knife bar with sections but without the head is $36 plus UPS (probably another $25). I didn't go with the bolted because I'm always close to the house and I don't have time to change hold downs, etc. I need to shove this knive in and go. I already have 2 heads, the old one and a new one already on the shelf (picked up on ebay last year for $10). A complete knive bar with head is almost double the price.
I could have bought just the bar for $23 but I didn't want to spend the time putting 28 sections on it. Freight is the same either way. Time is money. You either spend one or you spend the other. Right now I've got one small field baled and delivered (last night), another small field cut and being rained on as we speak, and a third small field with grass up to my headlights that I cut 3/4 of one lap before breaking the mower. At this rate I won't make enough money this year to fix the mower and pay for the gas!
