NH 56 rake gear box
Chris
06-16-2004 04:45:55
I have an older style NH 56 rake (the wheels are straight across from each other)
I have a serious grease leak and where the power shaft goes into the bottom of gear box - it wobbles right there
how tough is that gear box bearing/bushing seal thing to repair?
Steve from New Holland
06-17-2004 04:32:10
 Re: NH 56 rake gear box in reply to Chris, 06-16-2004 04:45:55
Chris, it is easy. As the other gentleman said, the vertical is easy, but the horizonal is not as easy. Pack it with 2 full tubes of grease gun grease. Do not use oil. Steve
paul
06-16-2004 07:11:20
I believe you would have a NH 55 model rake then?
NH officially recommends using grease in this gearbox now, but if yours is that loose go at it like the other person says....
--->Paul
txblu
06-16-2004 05:34:31
There should be cap, like on your truck's front axle, on top of the gear box. Removing the cap should put you looking at a nut. Remove the nut and the guts fall out on the ground.
I fixed the vertical problem on mine but the horiz seal was gone too (that drives the rake bars). Being lazy, and having an adequate repair on the drive line, including the seal, I just packed it with Lubriplate 105 grease. The viscosity of this grease is between NHGA (?) 2 and 90W oil. A little of it works out onto the shaft but it stays put.
Mark
