JD No. 5 Mower
Phil - MO
06-15-2004 10:35:45
If it ever quits raining here in the Ozarks I am ready to start cutting hay.
I mounted the JD No. 5 Mower on my JD 430 tractor. My deceased uncle wrote in the operators manual that he bought the mower in 1955. Might not have been new.
The mower has a metal grass board with a metal bar to direct the hay away from the end. Seems a little short to me. Is this an option?
I also found two old wooden grass boards that I could use.
The fescue is pretty high mixed with Orchard grass and Lespedeza (sp?).
Once it slows down raining, I don't want to stop to change things. Which should I use.
Phil - MO
06-16-2004 07:44:12
 Re: JD No. 5 Mower in reply to Phil - MO, 06-15-2004 10:35:45
Thanks for the comments.
As far as mounting the JD No. 5, I got all the measurements from the web site below. Mine was originally on a JD B with a foot lift. I still had the cabeling and also the hand lift is still installed. There was a quick tach option available, but might be hard to find now.
Link
Look toward the bottom of the opening page to Mounting JD No. 5 mower.
As far as attaching to my JD 430 I made two short drawbar extensions to attach to the mower for the right distances as given on the web site for clearances beind the wheel and offset to the side. I attached the lift cable to the 3-pt. to lift. Haven't used it much yet because of the rain, but everything seemed OK in a short test run.
Dan
06-15-2004 22:41:44
I have always used a wooden draft board. The only time I have damaged it was when the outer end dropped down when I was backing up. I have broken the wooden rod up from the board. The one I have now is a combination of a wood board and a metal one. In tall crops such as my oat hay last year I have sometimes had trouble with the crop hanging up on the rod. Didn't seem to make much difference whether I put it up or down. May just have been the nature of the oats. The number 5 is a good mower. I have used one a lot. I have not used it on my 430 but have used a #8 on it. How did you mount the mower? Was it quick tatch?
Allan in NE
06-15-2004 12:01:07
Phil,
Your uncle put that metal board on there for a reason.
The wood ones just weren't that stout and would easily break in heavy folage; especially alfalfa.
We did the same trick; the rod we made out of 3/4" stock and gave it a bit of a "throw-back" curve. We made the rod about 20 to 24" long which was shorter than the original wood one by a long shot.
It worked just fine as the forward momentum "rolled" the crop much like a plow 'rolls' the dirt. It stopped our running to town to buy a new board every so often.
Hope this helps,
Allan
