Ouch!
txblu
06-15-2004 06:25:56
Was restoring my worn out Ford 350 sq. baler (new rollers on the ram and reinforded the ram drive to baler interface).
Don't know how it happened but heard a bang and lo and behold I broke about 3/4" off the end of the "hootus" (need a name for it) that reaches around (like a curved index finger on your hand) and grabs the wire to do the knot twist. It is just enough to be totally unreliable. Bales 1 or 2 then won't tie 1 or 2 on that side.
Looks like it is part of the shaft that goes up to the chain drive. Just as well as there are lots of marks on the shaft where wire has run for lotta years. Probably won't hurt to redo the whole shebang. This is really sad as once you got the ram to cut and compress the hay, it did a great job of tying it off.
I understand other brand balers used this Ford patent which might get me into a newer baler and possibly a source for parts.
Thanks for any help
Mark
Jerry D in NC
06-15-2004 12:02:34
 Re: Ouch! in reply to txblu, 06-15-2004 06:25:56
Mark,
Do you know if the twisters were the same on the Ford 530 as the 350? If so then email me. I have unblocked the address....
txblu
06-16-2004 05:49:07
 Re: Re: Ouch! in reply to Jerry D in NC, 06-15-2004 12:02:34
I just emailed you but here is what I said:
Jerry,
Have no Idea but would try. Best I can tell, Ford designed a real simple, reliable wire twister (tieing) unit and lots of other folks used the patent. That being the case, it probably remained for a long time.
This is very distinctive as when you walk up and look at it, there is a chain drive triangle of 3 gears on the top of the tie'r with one larger gear chain driving the 2 smaller gears which are mounted on top of the 2 shafts that go down vertically towards the hay (about 8") and on the bottom of the shaft are the grab fingers I am talking about that are twisted by the chain drive. Down under the 3 gears, in the center, running fore and aft, is a larger gear which is driven off the trip mechanism on the side of the baler. Real simple, and few parts.
And thanks for your help
Mark
Jerry D in NC
06-16-2004 09:25:44
 Re: Re: Re: Ouch! in reply to txblu, 06-16-2004 05:49:07
Glad you posted here as well. I did not get the email. Try again as if they are the same I may know of a deal for you...
txblu
06-16-2004 09:33:57
 Re: Re: Re: Re: Ouch! in reply to Jerry D in NC, 06-16-2004 09:25:44
just did
CRUSADER
06-15-2004 10:06:59
From the discription you gave, it sounds like part of one of the twisters broke off. Not seeing the baler, I would say that it would be a good idea to replace both of them because when they get worn the wire will get hung up and not allow the assembly to tie properly or will jerk/break the twist. Check the shaft that the twister bolts on to. Sometimes its possible to turn them around and they will last for a few more years. Prior to joining the service in 1985 I worked at the New Holland store in Waco for almost two years (was trying to go to college also at the same time). Sorry, but I don't have much experience with the Ford hay balers. Hope this is of some help to you. If I can be of any assistance, send me an email.
later days mate,
Jim
txblu
06-16-2004 05:50:38
 Re: Re: Ouch! in reply to CRUSADER, 06-15-2004 10:06:59
Thanks,
Problem is that the twister seems to be part of the shaft. I see no mechanism for separating the two from one another.
Mark
CRUSADER
06-16-2004 08:56:43
 Re: Re: Re: Ouch! in reply to txblu, 06-16-2004 05:50:38
Mark,
There should be a bolt and nut securing the tieing assembly in place. Remove them and "swing" the assembly upwards. This should allow you the room need for repair and maintenance on the unit. Look closely at the twister on the shaft. It should have a 5/16' capscrew securing the twister on the shaft. If indeed it doesn't, I would remove the chain (might want to mark the timing marks for ease of reassembly) and drop the shaft out of there. Ford should have the parts, although they may need to order them. Or you may try one of the local independents that deal in aftermarket parts. While your in there, check to insure your brake, plates, and guides are okay.
later days mate,
Jim
txblu
06-16-2004 09:39:38
 Re: Re: Re: Re: Ouch! in reply to CRUSADER, 06-16-2004 08:56:43
Thanks,Jim
May be that paint has covered the screw if it is a hex socket. Otherwise I see no means for making the twister a different piece from the shaft. Makes sense though that they are different pieces. The twister is cast iron and the shaft is steel. Gotta be one there somewhere.
You mentioned timing.
What timing will I affect removing the tieing unit. Do I just have to keep the drive (1) and driven (2) gear teeth in the proper perspective (number of chain links between each)? If I don't rotate the assembly (any gear)over 360 degrees, and mark the gears shouldn't I be able to put it all back without hurting anything?
Thanks,
Mark
