ledeger plates
dave
06-14-2004 13:41:46
How are ledger plates attached to the guards? Is there any secret way to replace them? Can it be done without taking them off of the bar?As you can tell I am new to this. thanks dave
CRUSADER
06-15-2004 10:20:41
 Re: ledeger plates in reply to dave, 06-14-2004 13:41:46
This is a post that has good questions and VERY good answers. Please allow me to add a few things to it (for whatever it maybe worth). First Off, think about SAFETY!!!! Keep an eye on those digits and make sure ALL fingers and any other part of your body is out of the way. Also when installing and removing the sickle bar with the newly replaced/repaired gaurds, leave them a little loose so as to ease the insertion of the sickle bar. Depending what kind of piece of equipment you have, sometimes you can replace the knives without removing the sickle bar. Take the gaurds off where the bad knife is at and get your RIVET-EZE tool in there.
later days mate,
Jim
Bill
06-14-2004 18:15:53
JC has great info in his reply, but if you are really new to replacing ledger plates, hold down clips,guards, etc.I would recommend that you not take every guard off of the bar. Take them off fix them and put them back on as you go.
JC
06-14-2004 14:33:00
You have a job ahead of you, but hang tough and get it done and you will be pleased with your results.
First, remove the sickle knife. I would lubricate the sickle and the bolts that hold in the guards to help you get the job done easier.
Next, take off the guards. Look close at the inner most and outer most guard or set them aside as they are generally special in shape, so be sure to get them back where they belong.
Also, mark the holes that accomodate the hold downs so you can get them where they belong. Take note that the knife head hold down should have a taller arch, make sure it goes back to the spot you removed it from. The rest should be interchangable.
Inspect your wear plates and hold downs. Replace any that are badly worn. This will pay in the end.
Check the ledger plates that are on the inner and outer shoes, if they are worn, be ready to replace them also.
The ledger plates are held on by long rivits.
You should have an anvil or other suitagle heavy metal piece, a good machine hammer and a punch.
Be carful not to bend the guard, place it face down and hammer out the old rivit. You will see where the rivit is in the center of the guard.
Go to your impliment dealer for the correct rivits and plates or you may find the parts at TSC or similar farm store.
Rivit in the new plates, making sure you are getting them sitting squarely on the guard and tightened down.
Now do the inner and outer shoe plates.
Re install your wear plates and guards and hold downs.
Tighten well. Now install the sickle a few inches and see if you need to adjust. (Which you will)
Try to make your adjustments right ahead of your sickle, push it in a little, adjust a little, repeat until done.
You will want your sickle sections to sit flat on your ledger plates. You may have to smack your guards (they are mallable) to raise them or lower them, make sure not to hit the thin piece of iron on top as it will break.
Hammer the hold downs enough to snug it up, but make sure you don't get it too tight. Use used oil to lube the sickle and guards.
When all is done, gun the mower for 15 minutes at 1/2 throttle with the tractor sitting still and the bar down.
Shut it down and check for any metal overheating which you can re adjust and for loose bolts.
It would be a good time to check your other adjustments such as bar tilt and having the bar adjusted so the outer shoe is approx 1 1/2 inch forward of the inner shoe.
Then you ar ready to knock down some hay!
Good luck!
JC
06-14-2004 14:36:10
 Re: Re: ledeger plates in reply to JC, 06-14-2004 14:33:00
My typing is awful!!!
Don't GUN the mower as my typo suggested, RUN the mower. I forgot to mention that you should trun the mower over by hand to see if there are any obstructions before powering up.
dave
06-14-2004 17:04:47
 Re: Re: Re: ledeger plates in reply to JC, 06-14-2004 14:36:10
My typing is not so great also.when I looked back I saw I had spelled ledger wrong. thanks for all the info. I just bought a #46 NH trailer mower and am impressed with the few runs around the field I have taken.I used a quick hitch IH for years until it broke. I cannot belive how much better the NH is.dave
