Vermeer Disc Mower w/ Bent Roller
Joe
06-13-2004 05:24:54
Saw an ad for a Vermeer disc mower with bent roller. Not familiar with disc mowers, and was wondering what a bent roller would be and how much trouble/cost it would be to fix. Any ideas? Thanks.
James in NC
06-14-2004 07:32:21
 Re: Vermeer Disc Mower w/ Bent Roller in reply to Joe, 06-13-2004 05:24:54
I would assume that it is a conditioning roller. In which case if you wanted a trail type disc mower without the conditioner remove the roller otherwise look out it could be expensive.
Joe
06-15-2004 04:27:41
 Re: Re: Vermeer Disc Mower w/ Bent Roller in reply to James in NC, 06-14-2004 07:32:21
I was assuming it was a only a mower and nut a conditioner, but I suppose you may be right. Looks like I need to get the model number. If you are correct, do you really think it would work fine if you removed the rollers?
James in NC
06-15-2004 05:21:43
 Re: Re: Re: Vermeer Disc Mower w/ Bent Roller in reply to Joe, 06-15-2004 04:27:41
I would remove both rollers and save the parts just in case. As long as you remove all the obstructions I believe it will work. Take a look and the new Vermeer trailed disc mowers. They are virtualy the same thing.
Hay Dr
06-13-2004 20:30:22
Get the specific machine model first and then we can help you.
