Brush Hog
Jon Cutler
06-12-2004 19:13:21
I recently bought a tractor with a brush hog which had not been used in several years. The housing where the PTO shaft and the blade shaft connect is empty. should this be full of lubricant? If so what type?
Jon Cutler
06-14-2004 16:29:01
 Re: Brush Hog in reply to Jon Cutler, 06-12-2004 19:13:21
Thanks for the responses. I put some 80w90 gear oil in it so I could run it for the weekend. I will definitely check into that seal.
Steve from TN
06-13-2004 15:59:35
Until you get your seal replaced, pump some grease into the gearbox, maybe a tube and then fill up with 80-90.
marlowe
06-13-2004 05:39:20
fill with 90wt. to fill oil level plug. more then likley your output shaft seal is shot. had [3] brush hog come in last week end with burned up gear boxes and [1] yesterday all over a $8.00 seal
Tom in TN
06-12-2004 21:00:19
Jon,
My Big Bee brush hog uses 90 weight gear lube in the gear box. I would imagine that is pretty standard on this type of machine.
Good luck,
Tom in TN
