Oliver two bottom trail plow
farmerjohn
06-12-2004 18:43:16
My Dad just got an old oliver two bottom plow, we are not familiar with this make and are not clear on exactly how it is to work. It has "83 OLIVER" cast on the moldboards. It is on two steel wheels, has a crank adjustment on the right wheel, a rachet mechanism to adjust the left wheel, there is a "wing-shaped" bar which has cog-like teeth that engage in a drum-like gear on the left wheel to raise it up. There is no tail wheel, is it missing? Also there are no grease zerks anywhere, how do you grease it? Anyone know about this model or have a manual or info we are curious to know more about it.
TomH
06-13-2004 13:37:34
 Re: Oliver two bottom trail plow in reply to farmerjohn, 06-12-2004 18:43:16
Sounds like an Oliver #100. Yes, it should have a tail wheel. Is this what you have?
farmerjohn
06-13-2004 17:59:54
 Re: Re: Oliver two bottom trail plow in reply to TomH, 06-13-2004 13:37:34
No, the picture you link to is not it, however I found a picture exactly like it.
http://www.tractorshed.com/cgi-bin/gallery/iphoto_pic.cgi?pic=http;//www.tractorshed.com/gallery/iphotos/i1280.jpg&firstrec=1&lastrec=15&Parameter=oliver%20plow&mode=All&what=iphotos
Charley
06-13-2004 06:40:17
I had one of those plows. Just gave it to a friend a few weeks ago. I was curious about it as you are and did find out that it is called a "Rooster Comb" plow because of the shape of the rachet lift. Must have been a lot of them made and they were apparrently good plows. Mine had a lot of weld build up on the wings or I would have kept it.
