JD 336 baler
Gary
06-11-2004 20:05:41
Had the outside bearing on the hay pickup on our 336 baler go- can't see how the bearing comes off the shaft to be replaced- does the whole pickup drive shaft have to be removed to replace the bearing?
kyhayman
06-12-2004 17:20:58
 Re: JD 336 baler in reply to Gary, 06-11-2004 20:05:41
Flange mounted bearing, take the last stripper off and remove flange, bearing pulls off the end of the shaft. Takes 15 min (unless you have to heat the bearing).
