Thinking aloud. The springs are to put pressure on the roll. The bigger it gets, the more the pressure. I'm going to re read your first post and get back. I'm back. I was going to tell you to adjust tension on the spring mount but you said all of it was out already. You didn't indicate that your problem was starting the bale or getting a dense, full sized roll. ----- ----- ----- ----- ----- You didn't by chance leave your safety pins in did you? ----- ----- ----- ----- ----- There's one on each side which has a hole to store it in. The chamber is opened and the pin is inserted horizontally into a little hole about half way up the side of the chamber at the interface of the main bailer and the chamber door. Nothing happens mechanically, but when the chamber is closed, the belts have no tension; they are floppy. When they said safety pins, I thought they meant the chamber door would be jammed so that it couldn't fall. All that happens is the belts are loose so that you could crawl out if you got caught.....as long as your legs weren't broken by the door falling (if you had a gross hyd leak). Since tension is a function of belt length, I had a thought and that was to deliberately shorten the belts to less than the original length....if the springs are truly shot. Check your safety pins. Let me supply you with the OEM belt length. Pull a belt off and measure it. We'll go from there. If the belt is really too long, it might solve the problem; maybe to the point that you would have to put some length back into the spring adjustment. Mark
