Sorry for the long post - lots of questions!We have an old NH 66 baler with a Wisconsin engine on it. We were going to remove the engine, and get the clutch and parts to run it off the PTO. But, some folks wanted to borrow it and use it as a stationary baler. So, here we go trying to get it going. The engine is a 2 cyl air cooled unit. We already had the magneto rebuilt, so it's in good shape. It was really hard to time the magneto when we put it back together - the timing mark on the drive gear (meshing with the magneto gear) was not obviously apparent at all. Should we be looking for a punched hole, a score mark, two punched holes on adjacent teeth, or what? One of the intake valves is stuck. Anyone have any luck getting valves un-stuck without removing the head? I was thinking of soaking the area with penetrating oil, and gently tapping the valve closed, and letting the cam open it back up. Any other ideas? The fuel line keeps loosing its prime - is the most likely culprit a leaky fuel line fitting? Is the fuel pump supposed to be able to prime the pump by that little hand lever? (it's a real pain!) What's the best way to start these things - just keep turning the hand wheel? Lastly, is it possible to mount the PTO clutch stuff on the flywheel, and be able to use the baler as either PTO-driven or engine-driven? Has anyone ever done that? Thanks in advance...
